rick n ohio
I bought a brand new 3308 pull type brushhog one of the gearboxes keeps puking oil out the breath cap after about twenty minutes to a half hour of operation.i flipped flopped the breather with the other outside gearbox breather and the oil leak stayed with the same gearbox.dealer came picked it up took it in and put a new breather on it.i told him I switched them but maybe he had to find out himself.got it back and the same gearbox still leaks.im going to call him back in the morning.only thing I can think of is the bearing is to tight causing it to run hotter and build pressure.thought I would run it by you guys to see if anyone ever experienced this.
Thanks Rick
Thanks Rick
