Cutting up a round bale
coshoo
Not much experience with round bales, other than putting them in a feeder and letting the horses eat them up. Now, we need to feed a confined horse hay from a round bale- no way to unroll it, and it is stored such that we need to cut it up from one side to free up enough each day to feed the horse a measured amount (can't be free choice). Not really up to hacking away with a machete- any suggestions on how to cut into it? Don't think chain saw will work- any other ideas? Hedge trimmer? Electric kitchen knife? M79 Grenade Launcher?
I had big rounds up in the barn on the floor. There were two ways,unrolling them which was hard or removing the strings and taking the chainsaw and cutting them in quarters, hay would fall apart and I could fork it down the chute. It worked well, occasionally had to pull hay out of the drive sprocket but overall it works well and I fed a lot of big rounds that way.
use a chain saw. it works good. I also have used a reciprocating saw with 12 inch blade. I like the chain saw better.
(quoted from post at 21:24:45 05/22/18) I would find a place in town or a neighbor that sells square bales.
ome people just have to do things the hard way! :(
put the bale on its side, remove twines, unroll with pitchfork . you will be unrolling it the way it was rolled up in baler. very easy. thats the way i do it. feed out a whole bale this way. thats if you can get to it to move it.
I've always just cut them up with a chainsaw. Works fine just keep an eye on the drive sprocket. Clean it out as needed. I can remember Nasco used to sell a bar and chain just for cutting hay bales.
Thanks, all. Watched some videos, looks like chain saw is the way to go. Looks like if you cut with the top of the bar, it will throw the "hay dust" away from the saw and not clog things up. As I said in my original post, can't unroll it because I'd have no place to store the unrolled hay as we feed it out over several weeks to one horse. Horse is foundered, needs very low quality feed for awhile- we have some good small squares, but this one over-ripe round bale will be better for her.
I have tried The chain saw Method , but they tend to clog. Best thing I found was a circular saw blade on a Weedwhacker. It is a vicious looking tool, but it will cut a neat 6 inch deep slice along each side of a round bale and you can lift off the top arc of hay easily.
Wonder if this would work.
Says it is a hay knife.
http://www.laurelleaffarm.com/item-pages/hand-forged-hay-knife.htm
Local family here uses a chainsaw, they feed 3 or 4 horses that way daily. They been doing it that way for years.
Rick
My neighbor lifts his up with a winch and pushes a metal bar through that has a bearing so it can spin and a piece of flat iron and a lynch pin goes on the other end. Then you can unroll it. He has a JD baler and takes a little effort to push it through. Works pretty slick once you get it in position.
I have fed cows in a barn for years and I used a high tech device they call a pitch fork! Just go around the bale and unwind some, its one horse!
