(quoted from post at 08:30:47 05/22/18) To my knowledge, this only is important when you're dealing with things like air/oil struts on aircraft, which can get up where it's very cold, and a small amount of moisture could cause real problems.
Seems like I have heard about different gasses having different molecule size, so one might be less apt to leak out through a porous tube than another?
(quoted from post at 10:05:37 05/22/18) One of the main causes of rubber deterioration is ozone. The normal range at ground level is 10-15 parts per billion. It is the main cause of rubber cracking. If the dry nitrogen has no ozone it is better than regular air, but how do you protect the outside of the tire. The size of the nitrogen molecule does slow pressure loss and nitrogen does not change volume as much with temperature change as some other gases.
So ozone plus sunlight deteriorate rubber on the outside. I read over the PM article rather quickly, but ozone was not mentioned. I imagine the longivity of race car tires is too short to worry about ozone. The outside tire coatings usually contain some antioxidant which would slow cracking. Are there any treatments that have an antioxidant for the inside of the tire?
There are tire covers, but I don't know if they slow air movement at the tire surface but good ones stop sunlight deterioration. At the current price of tractor tires I wonder if it would be worth the time and effort to cover rear tires when there are periods of time say greater than a month where a tractor is not being used. I am going to look up any research to see if anyone has done any such study.
I would probably have to look it up on Proxmire's golden fleece awards.
s that figure before or after it's gone thru the compressor?(quoted from post at 10:19:20 05/22/18) Air also contains a variable amount of water vapor, on average around 1% at sea level, and 0.4% over the entire atmosphere.
Yes they are available and aren't limited to racecars. I've used them and didn't care much for them. Just one more thing to go wrong. I learned in racing that consistency was more important than horsepower. I've used nitrogen for years in my racecars mostly because I could predict the growth of a tire with heat added. An aired tired depending on the source could easily gain 4-10 lbs in just a few laps on a 1/2 mile asphalt oval whereas the same tire would gain consistently 2-3 lbs. I could predict that tire's circumference and consistency. I very rarely completely purged them probably could have had more consistency. Tire temps were 110 to 210 depending on position on the car. I've checked tire temps on my hauler and very rarely exceeded 110 degrees, treaded tires cool much better than racing slicks. I never saw a reason to put nitrogen in my vehicles other than when I had a soft tire on my hauler for the ride home. At such low temperatures they didn't grow that much and regular tires are much stronger to resist the growth.(quoted from post at 12:13:55 05/22/18) I also believe race cars have special valve stems that bleed off over inflation letting some air out.
(quoted from post at 08:02:20 05/22/18) Here is the scoop on tires filled with nitrogen.
Popular mechanics
