I have an Oliver 1655 diesel which I really like as mid size tractor-- Except. For the past three years it will just quit working and I cannot find or figure out what's causing it. I use it planting corn with a 4 row narrow, 2 years ago it quit once, acted like it was out of fuel. Checked the tank it was 3/4 full, then the sediment bowel and cleaned, then replaced the fuel filter which appeared clean and the fuel just flows freely--i.e. nothing blocking the tank outlet. It restarted and finished the field. Last year it was half a dozen times and each time the same thing--check everything then it restarted. This year after the forth time the fellow planting pulled it out of the way and finished with a borrowed tractor. Went out to fuss with it and it restarted doing nothing.
I keep thinking the injection pump and will have it rebuilt (about $1000) if that is the problem but how do I be sure? Hate to spend the money and find out that's not the issue.
