NEKS
Was going to use my 656 to move a pintle hitch trailer. Had a ball on the fast hitch drawbar. When the trailer dropped down the lift arms went clear up. Got on the tractor and when I move the lever nothing happens. The draft control lever went clear to the bottom. When go to move it up, acts like its spring loaded and goes back down to bottom. What did I tear up.
If the draft linkage is the same in that as the larger tractors it will be an easy fix by taking the top link holder or the cover above the pto off. Inside there is a lever that comes up from the bottom that pushes on another lever coming down from the top and what has happened is the one got past the other and is on the wrong side. Be careful it can have a sharp edge where they have rubbed together over the years, just pry the one carefully past the other to where it should be. This is on the right side of the opening. It's hard for me to explain in writing if you need more info my email is open and I will send you a phone number where I can talk you throughout it.
