stonerock
got 200 ac sprayed sunday, bean ground, got about 600 to go then corn ground....sprayed LV6, tricor,roundup power max, sonic with some array see what that does this year [centeral ohio]
stonerock what is the cost of spraying now per acre? your doing 800 acres with that mixture what is it going to end up costing you? (not counting fuel and tractor).
We have a ways to go for the ground to dry off some, some snow to melt away yet even.
We use some pre emerge around here, can't imagine spraying the mix you do at this time, there isn't anything green, little tiny bit ofthe lawn on the southern slopes is trying to show a tiny bit of life.
Used to get green growth before beans, but now we push the growing season so hard up here, if the ground is fit we field cultivate and follow with a planter, and nothing can be greened up yet.
Very little of what you are spraying would have any effect on anything put on bare ground 'here.' How different it is farming in different locations.
Paul
per acre sonic.17.25
tricor.3.28
2,4-D LV6 2.81
ROUNDUP POWERMAX 5.63
array 9.54
total of 32.88
app fee 7.00
39.88 per ac...times 800 ac =31904.00
(quoted from post at 12:01:28 04/25/18) per acre sonic.17.25
tricor.3.28
2,4-D LV6 2.81
array 9.54
total of 32.88
app fee 7.00
WOW that is a lot more than I thought it would be, but then I have never worked around bean or corn fields up here mainly hay and oat fields. stonerock the app fee is for application? I take it the fertilizer co. you got the product from is applying it?
