open gear lube
There is a special chain lube for open gears. I bought a case many years ago to use on the drive gears of our feed grinder. It is much more sticky than regular chain lube. Don't remember the brand and I used the last can about a year ago. Tom
A lot depends on whats around the open gears if its clean then a lube is good if its a lot dust and dirt flying around then you're better off with nothing to make particles stick to the gears.
Hello boboler76,
Mobil has one called dynagear series. Designed for mining loaded open gears,
Guido.
