Fuel filter issue 5055e
Has anyone changed the fuel filter on this tractor? Book does not show any fuel line cutoff. Tank is above filter. I don't know any way to change it other than spinning the old one off and putting the new one on with fuel running out.
clamp the rubber hose? If there is no cutoff, I'd be finding a good spot and
installing a valve for future situations.
I have 5065, from my book and how to bleed system. 5055 is the same.
Step 1 get new filter
Step 2 remove old filter by unscrewing large black retaining ring.
Step 3 fill new filter with fuel
Step 4 install new filter
Step 5 crank at 1/2 throttle...let run for 3 to 4 minutes.
No bleeding fuel system..
Use as needed.
