pat sublett
I have a Ford 6910. the front wheels are leaning in at the top because there is slack around the bolts that hold the axle together. I don't know whether they have the wrong bolts in them or the holes in the axle are worn. Any suggestions for fixing.
The only way to tell if the bolts are "wrong"(too small) or wallered is to take them out and physicly LOOK at them.since I am not familiar with that tractor I cant tell you anymore. However,I'll bet the bushings are worn/wallered.About the only way to fix is to look and repair/rebuild as needed.jack up the front end and shake it and see where the wiggle is.
