I no the title makes no sense but here it goes.
Whenever I manage to get it started it runs great. Plenti of power smooth idle.
i have been srewing with this thing for months.
Imposible to start most of the time, floods easily.
first I changed plugs cap rotor points and cond. no change
I figured I had a carb problem so I rebuilt it. no change.
I figured I had a bad core or I screwed it up. I bought a brand new Zenith carb . no change.
I thought it was not getting enough voltage to points while cranking ( bat drops to 10.8 while cranking so i put jumper wire direct to coil and I thought that fixed it. Until next time it did not help
Both the battery and starter have been abused, long periods of non use and excessive cranking in its present situation, but they both seem fine. It will crank at a decent rate for at least 30 seconds, maybe longer After sitting before starting bat is at 12.3 Even if I put a booster on it and get it near 14 still no start today. It is 43* today , not what I consider to cold
Point gap .025
timming at 3bt altough i do not have a working tach so I do not know if it was at 475
Compression test all cyl at 90 cold and dry
Help, snow is comming at some point and I need it for plowing
Thanks. Gary
Point gap .025
Thanks. Gary
