showcrop
This got me thinking about the other possibility with some tire removal jobs. There is always the possibility that the tire is just not going to come off. This can happen with old tire/rims, most likely if they have been lying flat in the weather for a few years. I picked up a pair of dual rims with old worthless tires on them. I tried the usual means of breaking the bead for awhile with no success. After an hour or two I called a friend. He told me to take my reciprocating saw and cut the tire off the bead, then take a cold chisel and cut the bead from the rim. The situation is that the rust that builds up on the bead area of the rim tightens the bead to the point that it just will not slide on the rough surface. In this situation where the tire is worthless it is not worth the time and effort to try to remove it whole.
