westendorf ta26 opinions
wlf89
are they good loaders? looking at one to put on my ford 6610. let me know what yall think how they compare to other brands
There are adjustable to fit lots of tractors . One of
our customers had one on a 4320 deere . Always working
on it and we finally just welded the adjustabilty out of
it . Then it was fine . I like the qtach easy to make
your own brackets .
They are fine IF your not hard on loaders. The mounts where very adaptable to many models of tractors. That kind of took the strength out of the mounting system. For lifting bales and such they usually are fine. IF your drive a lot on uneven ground with the bale up to where it puts a lot of side load on the loader the mounts will break. If you scrape yards and or move a lot of dirt/manure you will break/crack the mounts. The guys that load piled manure and lift on pretty level ground have good luck. On my hills they usually needed the mounts welded solid with some extra bracing to hold up.
Allied, Koyker, Bushog, and others are a heavier built loader.
