omplex compared to tank type, but in right circumstances, they do work. If electric, a biggie is that they draw so much current that most homes will need a new electric service panel. Son's propane needed a larger supply line.(quoted from post at 22:28:35 02/26/18) Anyone use a tankless water heater? Our water heater quit working and needs replacement. I'm considering going tankless and was looking fo r recommendations from folks who used them.
(quoted from post at 21:54:56 02/26/18) No experience with electric, but installed a nat gas heater for a friend a couple years ago.
It made endless hot water as promised, but if trying to just mix a little hot would not work. It takes a minimum flow for the heater to come on.
(quoted from post at 21:51:29 02/26/18) We have had an electric tankless for going on 10 years now. I will never go back. Need to note that we set the temp control to 115 degrees F. We run pure hot to shower with and only use 45 gallons per day average total water use throughout the year. Although the unit requires 2 60 amp breakers the electric bill reduced slightly after switching from the conventional tank heater. One downside is when electric goes out my 6500 Honda Generator will not do it. I will consider a propane powered one when this one needs replaced.
