KEB in GCMS
It has been a while since I asked for help on my JD 310C backhoe. It was not moving, but everything else was working hydraulic wise. Well I finally got to work on it yesterday, and pulled the bottom off of the reverser, and there was not any fluid in it. Found a hole in one of the lines off of the side of the reverser, all the fluid had been pumped out. So no fluid, no movement. So I cleaned the filter since I was in already, put everything back together added fluid and it works correctly. I also repaired the line that was broken. I didn't go look for the old post, but thanks to all that pointed me in the right direction and what to look for.
