Adirondack case guy
I carried in a salvaged (freebe)Kubota shipping crate into my shop today. Took my 4-1/2 grinder with HF cutoff discs and cut all the mtg. brackets that were welded to it off. It only took 2 discs to clean it off, at $.60 per disc.
This will be the third firewood hauler that I have built. Plan on staying with the flare side design. This crate measures 93" long X 45" wide, and will be the base frame for the dump body. I have an old IH running gear that I will use the rear axle assy out of it to build a chassis to mount the dump box on. It will need to be narrowed as I did on the others. My big hauler was made form the same crates but I extended it longer, using another crate. This one is bigger than the little trailer and shorter than the big one. I have a 1957 Case 300 RN to put on the little trailer and I will hook my 1963 Case 440 custom cab tractor to this new trailer. My little trailer will hold a bit over a cord when stacked on. this trailer should hold about the same without stacking, and my big trailer easily holds a cord.5 just dumped in from my splitter/elevator, and finessed a bit so nothing falls off.
It will be a dump trailer , but this one will have a tower lift utilizing a HF $50 buck winch with battery. Much much cheaper than incorporating hyd. cylinders and hoses, and will dump with any tow vehicle.
Stay tuned.
Loren
Stay tuned.
Loren
