After tracing wiring, repairing connections where needed, installing (2) different new 12 volt regulators, and going through the generator troubleshooting flowchart several times; I still can't get the IH 424 to charge. It has a 12 volt generator system with the 3 prong voltage regulator. I do just as the flowchart says and make it all the way to the end where I have to ground the field AND jumper the bat and gen terminals before it will turn off the "amp" dummy light on the dash. I've tried (2) new voltage regulators and get same results with both. The result is that the flow chart procedure tells me the regulator(s) is bad. Not likely that both a Standard Motor Products and a Napa brand part are both bad.
I can take a video or pictures of anything if you need it.
PLEASE HELP.
PLEASE HELP.
