Greetings All. I Need some help adjusting the clutch on my case 1190. I was okay on shift but PTO would not engage via clutch (PTO only worked by dead starting). I took off the cover plate underneath, and found 3 lock-nuts and threaded posts. Do I adjust those out (counter clockwise) towards the front end, or in (clock wise) towards the rear? I've tried a little both way with any success, except I seem to have lost my pedal returning. It falls all the way forward to the floor board just by gravity. I thought I better stop at this point and ask for some help. Also is it possible to simply adjust the clutch cam lever a notch or 2? I just wondered if could adjust for free play that way, but I can't figure out how to get it loose. Any advice is greatly appreciated
Thanks in advance!
Thanks in advance!
