I need to remove the flywheel on my 1953 JD 60 to replace the ring gear. I think my dad had a used taper lock type installed 30 years ago. I can't tell if the large square "nut" (4 &1/2 inch square) on the outside is threaded on? If so, is that a right-hand thread? I've not been able to move it.
And the two large crossing bolts that clamp the flywheel to the crank appear to have the nuts spot-welded on. Is that typical? Should my Map gas torch be able to melt those welds, or do I need to have an acetylene torch?
Any advice would be appreciated. I'm attaching a photo of the flywheel.
