I have a Husqvarna yth24v48ls tractor, starts, runs forward, reverse normal, but whenever engaged with pto switch, engine would shut off in a second, I check the seat safety switch, pto switch and the ignition switch all in good condition. I tried the ignition switch on the reverse position;take out the bridge in the seat switch wire plug;disconnect the reverse switch;unplug the clutch/brake switch. And each time it still kill the engine when pto engaged, I notice the blades is turning the moment when the pto switch turned on. Can any one point a direction to the root of the cause.
Thanks
Thanks
