Help finding serial number on tractor.
muddypunk
New User
Hello I'm new to the forum but understand the basics. I've had a Case 350 for about 5 years and last night it stopped going forward I'm not sure what happened but I think it'll be easier to order stuff knowing what it really is. The number tag is missing off the left hand control box and I'm unsure where else to look.
Don't think you would have much of a problem ordering parts without year or numbers because they only made them for a few years.
Probably not a lot of major changes changes.
is that the job you were doing when it stopped moving did you loss all motion or just forward ?did your high low leaver by your left foot get put in to neutral ?.
Disregard my post.
I thought you had an old J I Case 350 farm tractor.
From the pictures I call them dozers.
Once I had the same problem with a machine.
No serial number no parts.
Found someone with the same machine and used his serial number.
Take a close look at the mechanical linkage from the F-R lever. Probably just a pin fell out. Simple fix if you have any mechanical abilities.
Loren
Oh yeah it's cobbed bad down there. It's only having issues when it gets hot but figured out if I make laps to the right it seems to do ok. I need the rain to stop so I can wallow under it and open the diff/trans it's banging hard on the left side.
The 350 crawlers had a Clark tranny in them. 3 forward and a reverse. No high low rang gears.
Case updated the old 310Gs by eliminating the dry clutch and installing a torque converter with reverser in front of the Clark tranny.
Loren
