northeastpuller1
I was wondering what it cost to heat a house in the places that see 0 and minus 34 for days at a time. I have a 1850s 4000 square foot farm house .That has a lime stone basement a slab and a crawl space. The basement is spray foamed the walls have been insulated the attic has two layers crisscrossed of insulation about a foot thick. The outside has 2 layers overlapped of 1 inch solid insulation house rap and 22 newer windows and insulated doors. I bet I have used 5 case of spray foam insulation over the years chasing drafts. So the house is as tight as I can get it. I live in north east Pa about 45 minutes from Larry on the corner. If I burn oil with hot water in a normal year and a wood stove burning most of the day. I average 4 gallons of oil a day 365 days a year. With the t stat set at 62. I have switched to 2 pellet stoves and electric hot water and no oil. I can burn 5 to 8 ton of good pellets depending on the year with the T stat at 68. So what does it cost to keep warm in Canada and Minnesota?
