550Doug
- Location
- Southern Ontario
This carb is on a White 2-44LL/oliver 550 Industrial tractor. The manual I have says the MS carbs were either a TSX775 or a TSX603. I got the TSX775 carb kit and the main gasket was much too large and the needle valve too long. I then ordered the TSX603 carb kit and the main gasket is much too small and there was no needle or seat in the kit. The parts guy robbed a TSX605 kit he had for a MF135 and so I've now got a needle and seat that measures to be an exact fit. But I still have no gaskets the correct size.
ID mark on bottom is 4G
B15 is stamped here
This is the gasket for a TSX603
227 458 is seen here
I'm looking for help in getting the correct MS model for this carb.
Thanks
B15 is stamped here
Thanks
