Bobcat 763 oil change
Tony in SD
I?m considering changing to 15w40 synthetic oil in my Bobcat. It has had nothing but regular 15w40 oil in since it was new in the late ?90s. The engine has 2000 hours on it. My question is, is there any reason why I shouldn?t change to synthetic?
Look up the API requirements in the owners manual, compare to the oil you choose.
As long as it meets the requirements it will work.
Cost might be the only reason other than that I?ve switched back and forth from synthetic to regularl and the other way around lots of times with no ill effects
