(quoted from post at 08:03:32 11/28/17) That?s possible because they haydraulics are way strong on this tractor it will pick up anything whether it should or not
(quoted from post at 08:42:49 11/28/17) the cyl's do look upside down. and it does make a difference how they mount. the lifting pressure hose goes to the piston side of the cyl, not the rod side. this gives more contact area on the piston for easier lifting.you would need to check out the plumbing on them to see how they are installed as cant tell from picture.
