Goose
Yesterday I wanted to try out a plow I bought a couple of weeks ago. My D19 Allis ran about a minute and stopped.
The only reason a diesel will stop is lack of fuel. So-I started at the beginning, drained the fuel tank and unscrewed the sediment bowl from the bottom of the tank. My hunch was correct. The sediment bowl was plugged with goo that wouldn't let fuel leave the tank. Cleaned that up, but ran out of time.
This morning, I finished bleeding the fuel line to the pump and got the old gal fired up again. Hooked onto the plow and made less than a round before someone's half arsed weld broke on the lift cylinder mount. (See photo. Only about a fourth of the weld was holding). When the weld broke, the plow sucked itself deeper into the ground. Spent a couple of hours pulling the plow apart. Naturally it was in an unhandy place several hundred yards from the shop. Took the parts to the shop where I can redo the weld. Doesn't look like the weld even had any penetration.
Redoing the weld and putting the plow back together will be tomorrow afternoon's project. We go to church Saturday evening, but I make a point of not working on Sunday morning.
But, that's the only negative I've found on the plow. I noticed that weld had been redone when I bought the plow, but the moldboards were scoured so I figured the weld was holding.
