Sloppy steering
Mark Poss
I have to pull two small gravity wagons around twenty miles loaded with ear corn with a pickup this weekend. One wagon pulls good at around forty miles an hour the other about twenty. I want to pull them together to save a trip would it make a difference by putting the sloppy one behind the truck or not? Thanks for your time
Putting the sloppy one behind the truck and the better one to the rear is setting it up for crack the whip. Put the better one behind the truck.
Might be worth your time to try to take some of the slop out of the steering. Check for worn tie rod ends and check the toe-in.
Either way is unsafe even at 20 mph. You really don't want to clean up a spilled load on the road, do you? Keep your speed under 15 mph or use a tractor. Better yet, fix the wagon. Ben
This was posted just a couple of weeks ago. Tractor and follow me truck behind you with winky blinkies on!!!
Farm wagons on the road are an accident waiting to happen. Get yourself a truck.
Save a trip sounds like it could be very costly. your only talking one hour and a half vs possible catastrophe. Remember your not the only one on the road. You must consider the danger to others when that wagon whips you or itself into the other lane. Make two trips. Take it slow and easy. Probably won't need to say, " I WISH I WOULD HAVE ??????". jmho gobble
Put the sloppy one in back. Then just drive according to that one in back.
As for going 40 with a gravity wagon. We have one I pull about 50 on the road empty with a pickup. Old truck frame and is right where you are if you drive straight it is there.
Any wagon with a good front end should do fifty no problem. Not saying I would though. I wouldn't want to have a sloppy one tied in with another one though, front or back.
Well your only legal up to 25 MPH anyway. So why try to pull a wagon loaded at 40 MPH??? IF anything happens your in deep DODO. Also is pulling two loaded wagons behind a pickup legal??? Here in Iowa it is not. One wagon only. Two behind a tractor.
If you run a spring from the tongue to one tie rod end to hold the slop to one side it will do wonders for holding the wagon steady. If you get too much tire scuffing you need to fix the wagon.
But take two trips.
