olgentdc
Just not satisfied with the fuel return dribble drop . when i open the fuel return line and operate the hand pump i get fuel thru easily with each stroke.. then when all tite and engine running Nothing but a drop dribble come through the return nipple while idling ,. this is my 4th injector pump. each time , every single one broke the ROTOR ... i learned from others that the fuel return is stopped up somewhere .not sure if i have a problem , but it seems that this motor is not cured yet . ever so often at idle the engine will stutter /stammer and puff smoke..i need some ideas,. thanks for your thoughts.
