fixerupper
An old military generator from the late 40's with a Willys engine I'm working on has had some kind of gunk poured in the radiator at some time. I assume it's a sealer of some sort. The bottom side of the radiator cap was coated with the brown greasy stuff and
the rad cores have little chunks of it stuck in the tops of the cores. What can I use to flush it out? It appears this thing doesn't have many hours on it, the hour meter reads 106 hours if it can be trusted. The radiator is very clean except for this gunk. Do I use vinegar or is there something else that will work? Thanks
