I keep reading conflicting terminology and info and am trying to get this straight in my head so I don't get myself in trouble. And I'm new to tractors so apologies for a basic question.
I just got a 1971 Massey 175. The PTO on this one has a shifter to the left of the seat that goes from ENGINE to NEUTRAL to GROUND. This is considered a "LIVE" PTO, correct?
In either case, when running a bush hog, do I need to use an Over Running Coupler or Clutch on this tractor? Without one, the PTO does continue spinning after you shift it into neutral. Is this what people are referring to when they say that the continued spinning of the PTO can propel the tractor forward when you're trying to stop?
And if I do need the coupler, the shaft on my bush hog will need to be shortened. Do I trim the male or female end, or does it matter? Any advice on the best way to trim it?
Thanks.
Thanks.
