Bearing Interchange Question
Kerwin
I've got two old Aetna AG-1100-PS bearings that I'm trying to replace. Anyone know a cross-reference number that would work? 1 inch shaft diameter. They are
similar to the lock collar bearing that fits in a flange pair, except it's all one piece and instead of a lock collar the bearing has an integral collar and you
use a 1/4 roll pin through the shaft.
In case you were wondering, these bearings are from the dragline for a Kewanee 500 elevator. Parts book lists the bearings as PN X-5652. I should probably find a Bush Hog dealer to see if they are still available from them, but thought I'd check to see if something was readily available from other sources. Might be something special that was only ordered by Kewanee, however.
eBay flange bearing. My jd hay elevator had bearings like you describe. I was able to find a suitable match on eBay. Not an exact match but close enough to make work.
is this ithttp://www.ebay.com/itm/Bush-Hog-BEARING-104-105-1050-1051-109-1109-1115-1126-1126LS-1126RS-115-/331244261877?hash=item4d1fb251f5:g:2fQAAOSw5cNYXWUn
That's my first thought and will try that route if I can't find the original style bearings at a decent price.
