New Holland 1033 Stackliner question
Alan K
Spotted one of these on a sale. Was wondering if a New Holland 1033 Stackliner is one that you can unload bales into an elevator or is it just made to stack bales? Im guessing just for stacking since it is a "Stackliner" is this correct?
You cannot unload single baled with a 1033. It will only stand up a full load of 105 bales.As faras I know,a 1010 is the only one capable of single bale unload.
Alan, may want to call Roeders and ask to make sure.. i bought my 1012 from them and the info sheet says its not a single bale unload but it is..FYI
I looked at that list and I'm confused. Pa and I put many a small square with what I remember being a 1032 and that one would unload a single bale. It was 30+ years ago, but I recall single wheels, not tandem. The full load was 64. 7 rows on the deck and 1 on the table. I have looked for bale wagon info in the past and nothing I find confirms a 1032 to be the correct model for 64 bale with side unload.
I wondered about a couple of the numbers. We had a 1010 and with no ties in it we hauled 56, they list the top number at 55.
We never stacked, but I recall the holes in the deck and the hydraulic rams for push off.
As I jog my memory I remember the neighbor down the road had a wagon before we got ours. He also put his hay in the barn and I'm pretty sure his was a 1010. It had the plywood sides where ours came with the metal sides. I Don't know that that has any bearing on vintage or model number.
I find Roeders to not be completely accurate. A 1010 holds 7 layers of 8 bales per tier 8x7=56. It's good guide but I'd do a google search of a model number to see if it really does or doesn't have a cross chain to single bale unload
A 1010 does have the holes in the deck for some feet. Most of the other models the feet hydraulically push the load off. On the 1010 the feet are stationary and only bump the load back a few inches. I have to put a 2x4 in there and tie it back to pull the load off. It's a big time consuming pain but it's what I have.
