So I'm trying to install a petronix pointsless system in a continental Z134 with no real success. I finally got spark at the plugs (thanks, to everyone who commented in the below thread), however the problem is that
1) Its a VERY small spark, its blue, but its tiny. Might be enough?
2) The engine will still show ZERO signs of life under ANY circumstances. I know that it has good compression and I just rebuilt its carb (likely the problem, haha). However it IS getting gas (as evidenced by the raw gas smell in the air as its cranking) but the engine won't produce even a cough. If it matters, it has a Marvel TSX carb.
Absolutely nothing.
What should I do?
I thought it was a timing problem until I loosened the distributor and rotated it 360 degrees, slowly, while cranking said engine. As mentioned, theres not even a cough. I was taught that if an engine had fuel, compression and spark it would at least show SOME minute sign of life. Was this incorrect?
I dont even have a theory as to whats wrong with this.
Anyone have any thoughts on the matter? Thank you.
Absolutely nothing.
What should I do?
