HVFDfirefighter
Head not leaking anymore YEAH! Trying to start it So I can warm it up and retorque.I checked all plugs, and have good spark. I checked and rechecked firing order 1342. Checked to make sure wires are on right. Put a little gas in spark plug holes, tractor will fire, but won't run from carb. There is gas in. The tank. I took drain plug out of carb, there is gas in the carb. When I rebuilt carb, maybe I missed something. It's a zenith. Did not use spring on needle and seat inside carb as there is no way to attach ( didn't have one on at first either) I have idle screw set at (All the way in and out 1.5) I had a 1/8 " plug missing from the new exhaust manifold. Took the one out of the old manifold and put in the new. Could it be leaking air between manifold gaskets? I'm thinking more of a carb problem. Any help is always appreciated.
