Gresen 550 Hydraulic Valve
Don Boron
New User
I have a Gresen 550 hydraulic control valve on a Ferguson TO35. It currently is set up with a single Quick Connect outlet running a single-action cylinder. Can this valve be configured to run a double-action cylinder? Can it be set up to run either?
Oh boy if I remember right from my Gresen days the 550 was replaced by the model 300 which can not be used to run a double acting cylinder. Do you need to run both single and double acting cylinders? My e-mail is open send me a reply. J.
I would prefer to be able to run both. The 550 appears to have two ports, one of which is currently used for a single output, but there is another port right next to it which has a plug in it. That would suggest the possibility of a second line for a double-acting cylinder, but I don't see any other adjustment that would suggest switching between one or two outputs.
Like I sad the 300 is that way too, but internally it is different Send me an e-mail and I can send you some information. J.
J., Thanks for your responses.
This is my first use of the forum. I looked at your profile, and there is not e-mail address, so I'm not sure how to contact you by e-mail.
Don
