Starting a old diesel tractor
gyroman
New User
I have a 1968 Kubota L285 diesel tractor, my question is the tractor is a little hard to start even in the summer, it runs good once it starts. I checked the glow plugs and the manual says they should read 1.5 ohms. Mine each read 2.2 ohms. Does that make any difference in the glow plugs working properly. I also thought maybe the injectors were dirty and was wondering if I should put something in the fuel to help clean them. Thanks for any response.
If it runs well once it starts, it's most certainly a glow plug problem.
The higher the resistance of a glow plug the less it heats up. A fresh set of glow plugs should solve your starting problem. While you are at it check the glow plug wiring and solenoid for corroded terminals, etc and repair as necessary.
Yes, as said replace glow plugs. Kubotas are especially finicky with
start up. At least all the ones we have anyway. I call them fair weather
engines. Even in the summer time you have to hang on the glow plugs for
15-30 seconds depending what model you have. It's important to keep them
up to date, as your starter will work harder and fail sooner.
Are your sure about the relationship between resistance and heating up? I'm thinking that for a glow plug or wire, the higher resistance would generate more heat.
I agree with the glow plug diagnosis.
This may help and at the very least is a good 'bit by the dumb-a$$ bug' story.
My Cat 301.5 mini was hard to start but ran like a champ once running. So, I decide it must be glow plugs and check them with the VOM. All 3 tested within range. Problem was, I neglected to realize that there was a single hot lead bridging all 3 plugs and I didn't isolate each plug when tested!! So after a few dope-slaps I isolated the plugs and sure enough, 1 of 3 bad. Any chance you've fallen into the same hole?
(quoted from post at 13:02:08 08/29/17) Yes, as said replace glow plugs. Kubotas are especially finicky with
start up. At least all the ones we have anyway. I call them fair weather engines.
Hard cold starting on older Kubota engines may be a fact BUT my '11 M7040 starts very easily in Texas winter temp's.
Am I sure? Absolutely!
Why? The more watts passing thru a glow plug, the hotter it will get.
A mathematical explanation:
Rearranging with Ohm's law (E = I x R; where E is volts, I is current and R is resistance) you get I = E/R. And the heat released (watts) thru a resistance is I squared x R
Now assuming a 12 volt supply and 1.2 ohm glow plugs, a good plug will draw 12 / 1.2 = 10 amps. And (10)squared x 1.2 = 120 watts of heat released
But a 2.2 ohm plug will draw only 12 / 2.2 = 5.5 amps. And 5.5(squared) x 2.2 = 66 watts.
Bottom line is a worn, 2.2 ohm resistance plug will consume only about half the wattage of new plug. So it will heat up considerably less.
Incidentally my experience with older Kubotas is they indeed need good glow plugs (also a good battery!) to start reliably, even in warmer weather.
I've had 2 Kubota tractors a L245 and a L3400, both needed glow plugs to start, even in the summer. if it doesn't start easy after using the glow plugs you have other problems.
been doing KUBOTAS for 28 years and yes your 50 year old tractor more than likely has at least one bad glow plug. Best thing is to remove the plug the but the current to it a see if it is heating but I am betting you have weak or burned plugs.
I would probably buy one glow plug and test it with my meter before I bought the other three. But sometimes it takes me forever to fix things.
Zeke B.
(quoted from post at 14:54:22 08/29/17) Am I sure? Absolutely!
Never heard of watt flow before,
is that something new?
Both my newer Kubotas (1999 and a 2003) start without glow plugs to well below freezing but these guys know their stuff on older models.
Thanks Bob M, Your explanation makes sense to me, the resistance is keeping the glow plug from heating to the max.
Good job
The resistance of a glow plug is dependent on temperature. Does the manual state at what temperature that spec is for? When did you measure resistance, engine hot/warm, temp outside? The hotter it is (ambient or engine temp) the more resistance it will have. Since all plugs measure 2.2ohms I doubt the plugs are the problem.
Understanding how a glow plug is made and works, 1.5 and 2.2 ohms is not a significant difference. Incidentally you can also get a good idea on a cylinder that is weak or misfiring by measuring glow plug resistance on a warm running engine. The glow plug with a lower resistance is weak or misfiring cylinder.
(quoted from post at 13:29:03 08/29/17) I have a 1968 Kubota L285 diesel tractor, my question is the tractor is a little hard to start even in the summer, it runs good once it starts. I checked the glow plugs and the manual says they should read 1.5 ohms. Mine each read 2.2 ohms. Does that make any difference in the glow plugs working properly. I also thought maybe the injectors were dirty and was wondering if I should put something in the fuel to help clean them. Thanks for any response.
How long are you running the plugs?
Those older ones need 30 seconds or more in warm weather.
Reply for 4play, I checked the glow plug resistance at ambient temp. probably about 75 degrees. The manual doesn't say to check hot or cold I assumed ambient temp. My duramax glow plugs for example read about .7,.8 ohms. on the bench.
Thanks for the reply
