HVFDfirefighter
OK, I got the #8 valve moving (it was stuck). Had to remove head. Got everything cleaned up. Put on new head gasket, blue side up. Tightened all nuts a little at a time until all were finally at 65#. I then put rocker arm assembly on and tightens the three nuts to 50#. Now I need to adjust th valve lash. Not much help in the IT book. Found these directionsnon line, do they sound right?
" Bring No1 piston (near the radiator) to TDC on the compression stroke and adjust valves 1,2,3 & 5 counting from the radiator. Then rotate engine one full turn and adjust 4,6,7 & 8. Set them at .017" cold"
If this is not correct, anyone have a set of directions for me?
On a side note, I also took oil pan off. There is one heck of a huge dent on the back (furthest from radiator). I can see where it was brazed. It does not leak. I cleaned the screen on the float for the oil pump it was filthy. I'm afraid to take dent out because it may crack then I have to buy a new pan. Just found out today the intake/exhaust manifold is shot (huge holes in the bottom of the cast. I know I need one. This tractor is starting to act like a boat (always needs something). It is fun working on it with my 13 year old son. Starting to get expensive though.
