HVFDfirefighter
I had to remove head on my Super A to get at a stuck valve. I have that problem taken care of. I also removed the oil pan. The oil pump screen was filthy. Also drained maybe quart of water out of pan first. Wondering if I should flush the engine block since it is all open. By flushing I mean spray something (water?) in the holes in the top of cylinder block and letting it drain out the bottom hopefully washing out all gunk in the process.
If this can be done, where do spray the water? Also thinking of spraying water up through bottom.
Any help is always apprciated.
