Versatile 835's
Camboted
We're running two Versatile 835's in Cambodia raising rice and can't find the oil seal for the outside of the axle. Does anyone know where I can get some for a reasonable price?
Unless these are some special made seals, usually they can be bought from a bearing supply.
Sometimes the manufacturers number will be on the seal.
If it's a metric seal (very likely) the numbers can be decoded. Example, 50 70 10 would be 50mm shaft diameter, 70mm housing bore, 10mm width.
Or some accurate measurements can be taken, the seal lip design located on a comparison chart, and the seals can be identified or substituted for something that will work.
I'm having trouble cross referencing the seal part number to Timkin or anything else, but I did find the dimensions on New Holland's parts catalog.
SEAL,142.24mm ID x 190.68mm OD x 15.37mm Thk
Hope that gives you a little to work from. Good luck.
