Donkeyguy203
New User
Hi everyone. We have a 474 international which as I understand should be the same as 584. The problem is, we took off the injection pump to have it rebuilt as it was leaking. The tractor ran perfect other than the leak. When removing the pump I was not sure to losen the middle big nut or the three other smaller nuts (inside the engine). I losened the the three smaller bolts and in doing so I believe i moved it from the original position within the slots. I tightened those nuts, removed the old pump, installed the new pump. It ran however not right. So i played with the adjustment on the two bolts that hold it on to the tractor as there is play there. Got it running ok but it smokes and lack of power. So, I have spent many hours online looking for the specs on how to time the engine. I do see lines on the front pulley and a pointer. Also as i looked up service manuals, im not sure if they would even have the info i need to get this tractor back timed properly. Hopefully someone on here could give me a bit of help. I am new on here, thanks
Neil
Neil
