Funtwohunt
I have a diesel power unit on a pivot. The alternator quit working so I replaced it with a reman one. Fired up engine and the alt. was putting out 16V and the amp gauge was pegged out a 60+ amps. After about 2 minutes the alt. started smoking so I shut it down right away. Alt was toast. Put another oe on and fired it up and was charging 14.5 volts. But amp gauge was still pegged out. Thought it might be ok. NOT... after a few minutes this alt started to smoke as well. Any ideas what might be wrong? possible short some where. The battery still had 11.5 volts enough to start the engine. Someone told me if the battery was completely dead it might ruin the alternator. This is not the case. Any ideas as to what might be going on? Thanks funtwohunt
