Hi Folks
I have an issue with my Ferguson TO30.
It started bogging down and running very rough while I was bush hogging with it, I was barely able to get it out of the field. It will
run smoothly for a bit and then rough as a cob.
It had been rained on, but that had never been much of an issue before. At any rate I drained the gas and no better, still rough. Friend
of mine said maybe the coil had gotten too hot (we had done the 12v conversion last year) I put a new coil on it and it runs just the
same.
Replaced the plugs, which looked really dark and flooded and no difference. Now the new plugs look just like the others did, dark and
flooded.
I put the multi tester on it and the voltage seems good out of the coil, but I'm still not getting a super strong blue spark out of it.
I lightly sanded the points and rotor and it seemed to improve for a second or two, but as soon as I tried to drive it, it was back to
being very under-powered and will not idle.
Trash in the carb?
Any thoughts?
I appreciate the help.
Thanks,
WAMcGee
same.
flooded.
Trash in the carb?
Any thoughts?
Thanks,
WAMcGee
