Please tell me I'm not the only dumb one today
notjustair
Boy howdy I pulled a good one today.
I should be combining wheat ahead of impending rain but the unloading gearbox went out on the 9500. JD couldn't get the parts until tomorrow morning, so since I'm also not done planting beans I decided that better happen. The 25th is fast approaching.
I had the planter filled so I hopped in the tractor and went up the hill to a 40 on the section corner. It would be a full 40 but there is a jag of timber that juts out into the middle of it.
I've been fighting the monitor for the 1760 so it hasn't been rare this year for it to beep random rows so I kind of ignore it. It usually irons itself out after a few acres. It never ironed out and was hitting on what seemed like random rows so I kept checking the pin connectors and stuff. It wasn't until I was about half done that I lifted the lid on one of the boxes. Still brim full. I was mad until I realized that some weren't!! I quickly became queasy.
I had unfolded the planter and started planting without taking the covers off of the vacuum tubes. Half of the 12 rows weren't planting - the outside 3 on each side. So every two passes I was missing the center six rows. Except for the headlands of course. That had six missing in the middle and three on the outside and three on the crop side.
I can't say as I have ever gotten into such a pickle. I stepped off that field five times row by row (including digging in the rows) to determine exactly where the skips were for the whole field and get my mind wrapped around the fix. Then I offset 15 feet and went back over it like I was planting but I switched the row shutoff back and forth shutting off the left or right half each time. Of course, I do my own spraying so I wanted the rows to match exactly. It also makes it nice that it was right there on the road. Ugh. What should have taken me three hours took me six.
Am I the only dumb one today?
Had to re drill about 30 acres where the air drill left a 4 foot skip each pass nobody caught it until it came up
I had to replace a down pressure spring on my Jennie and did not reset the pressure. I planted 20 acres with the #15 row putting beans on top of the ground. We all know anytime the planter messes up it's along the road. If it would of rained they may have grew but we went 3 weeks without rain .
Back in the 1980s I had a JD 7000 6x30 planter. One row had a bad sensor in it. I was going to get one the next time I was in town. So I just shut that row off in the monitor. I was planting a field for a customer. One of the most traveled roads in the county at the time. He wanted me to plant one variety completely out and then switch to another in this field. About half way across the field one row ran out of seed. The row next to it had more seed in it. So I took the fuller box and dumped half in the planter to get across the field. AT the head land I filled all the boxes. I planted those nine units without stopping as it was a perfect laying field. Checked the boxes and one was still clear full. The one I had dumped was the one with the bad sensor. I forgot to trip the drive back in gear on that one row. So I planted 25 acres with one row missing. I had not marked where I switched varieties either. I over planted until I thought I had replanted everything. Missed it by two rounds. Right on the corner where everyone would see it as they came up on that curve. I tried to come back and plant the missed corn but the owner was so POed he would not even let me back in the field. Lost all of his planting and harvesting work.
Ever since then I keep the monitor working 100% of the time. A $25 sensor cost me thousands in income.
Nope not the only one. Gas got down to $1.90 and some stations was starting to go up to $2.39. So I decided to fill the 100gal tank in the back of my truck. It was at walmart so I put some money on a card for the extra 3cents off. I fill the tank and decide to fill the truck with diesel with the rest of the card. Never dawned on me I grabbed the UL nozzle until I go to put it back. A quick trip home to drain the tank and refill with diesel and it's ok again. But my butt still hurts from me kicking it.
Remind me of what happened to me . Planted corn for my brother and a friend , near 100 acres planted with my air planter. The moniter was acting up , and each time we checked, all rows were planting normal , while the moniter said "row fail". So after a while , I just shut the darn thing off. Got home and planted my own corn, field was low and a bit wet in some places. Wouldn't you know , some time after about the first round , some mud plugged up one seed drop. Naturally I had no way to know , and planted all of my corn with one row blank. The other guys fields all planted normal .Took a lot of teasing , but what can you do. Put a new wire harness on the planter for next year.
Have any of you drove off with the unloading auger still running I reseeded about 50 yards before I found my mistake boy I felt dumb. Randy
This year in the end rows in the first field of the season planting corn a rock stuck in one of the row depth wheels and the wheel was sliding along, leaving a row of seed laying on top. These end rows are a mile long, winding alongside a dredge ditch, I made a round and a half with the rock stuck in the wheel. I was glancing back at the planter once in awhile but the soil was dry and that one row didn't look any different from the rest of the rows. This field is directly south of my house so I have to look that skip for An entire year.
You're calling yourself dumb, when I'm sitting here thinking that you're a pretty smart guy to figure out a way to fix it.
J D,
I had a Deere 7000 8x30 planter years ago that the monitor would sound every so often in the middle of a field for seemingly no reason at all. The population would drop off and I just knew that it must be the radar speed sensor. I even took it out on a gravel road and tested it and it was planting perfect. Besides I had planted thousands of acres with that planter and never missed a beat so it had to be something in that monitor. Come to find out I had greased the main mechanical clutch too much and it was working apart while going across the field. Just a washer behind a cotter pin was enough to tighten up tension spring on the clutch cured the problem but that field sure looked like it suffered from a lot of cultivator blight when it came up. Another case if a person could sell their experience for half of what it had cost you could be very wealthy.
In the early 80's, we had a new JD 7000. They had a shut off for each planting unit. So guess who forgot to turn on a row?? Oh, and monitor!!! We didn't need no stinking monitor!! That cost money!!
And we were no tilling corn, in a clover/mixed grass field, so the rows were hard to even see. Plus, the field was pretty steep, irregular, and it was terraces, so we were planting on the contour.
Try fixing that!!! I planted 4 or 5 acres that way, then had to go back over the contour with only one row turned on. What a mess.
Glad that is all behind me.
Gene
I have a few acres of 28 foot strips in several of my fields this year. Seems the "Bri-lite" plug in connectors between the air seeder and tank lose contact on a short turn some times and shut down the metering auger. It must have shut down the shaft monitor too as no alert sounded. Just lucky I looked back and could see nothing turning. I'll just have to close my eyes driving by those fields til after harvest. Of course the worst is right by a busy grid road intersection. :-(
(quoted from post at 21:05:33 06/22/17) Boy howdy I pulled a good one today.
Done a lot of dumb stuff in my time and with regrets for some of it. live and learn is my motto and when the flags go up pay attention to them.
I feel your pain. A few years I was planting with the new planter for the first time (I was the backup planting guy)Of course it was in a field that wrapped around a subdivision. Same thing with the vacuum happened to me except it was only three rows on the right side. People I knew watched me plant that field. The monitor was making the same sound as the old one for low population, didn't even register in my mind. Embarrassing, but we were able to take the 3pt. four row and fix it. Only one person ever said anything to me. Lol.
