steve terplak
Re-assembling a U joint, out spider bearing in, pressed caps, put clips in. Good to go.
Did the other set, pressed caps, one went on, other has a 1/16" gap all the way around, won't go tighter. I assume one of the little bearing pins slipped out of place and is sitting under the cap.
Any tips for disassembly?
It has been a couple years since I have done one. I remember the last time I did it, whatever method I came up with was the hard way.
I seem to remember a discussion on here shortly after and I thought: "if I only knew this then, I will file this tip away for the next time".
Well. Next time is here and my file is empty.
Any tips/tricks?
Any tips/tricks?
