Hydraulics problem
mora55051
New User
I have a 400 farmall. the front hydraulics work fine, but the back one is only set up for a one way cylinder, how do i change it to 2 way, plus, the power steering works better to the right than to the left.
On top of the valve body are a couple of adjustments you can make which switch them form single to double acting. You may have to remove some sheet metal to get to them been to many years since I messed with them on a friends 450
Each valve, as old indicates, has a knob that turns (about 90 degrees). it has two flat sides and a roll pin on it. The roll pin should be contained in a sheet metal
"guide". There is an S on one side and a D on the other. Single or Double acting. It can easily be twisted too far, be careful. Jim
