Hello all
I have a problem that my TE 20 arms wont lift.
Have fitted a new control valve and upon inspection with the side covers of the fork does not close the valve. There is good tension on the spring, if I put my hand in and push the fork towards the front (close the valve) the arms lift and will stay up overnight. As soon a I let the arms down it will not lift again. I removed the draft control spring on the rear and if I lift the plunger rod up the arms lift (simulating an implement hitting an obstacle) has anyone got any ideas what this problem is because its got me baffled
Thanks
Rob
Thanks
Rob
