8630 remotes
Looking at a Deere 8630 but only has two remotes and I really need 3 minimum. What I'm wondering is what would be the options for a 3rd remote? Is it something Deere could do for a reasonable price or would it be insanely priced or what other options do I have
Should be able to get parts salvage yard. My 8430 has 3 and the 8630 my neighbor that I farm with also had 3. I believe you are also located in Southern Indiana? If that's​ correct call Worley salvage,they should be able to set you up.
There are aftermarket add on remotes to be had reasonably if you have enough flow rate to basically split remote into to halves. I believe then you switch between which remote is controlled with a switch in the cab. Looked into one for our sprayer tractor before we found an olger rogator instead.
Good luck
Joe
Worley's had crossed my mind. Just need the third for our carts hydraulic spout and possibly planter markers if it has enough flow to run the vacuum on our splitter
It is just bolting on another base housing and then adding the extra remote valve/coupler to it. These parts are not hard to find used. I would think new would not be available anyway and very high priced if they where. As for running vacuum systems and such an JD 8630 did not have massive hydraulic flow. Remember they where designed in the early 1970s. running cylinders was the main thing they would have done. High flow hydraulic motors where not in common usage then. They also would be a 2250 PSI system too.
80s-90s I added a third remote to two of my field tractors. I had added a hyd hitch and spout to the field chopper, so with the header, I needed 3 remotes. New from JD at the time was about a grand. Found units in salvage yards, those that advertise half-price parts...Worthington. But when it came to those remotes, they wanted about 700 for them. Lots of demand at the time.
