Model 422437. Type 105001 Code 87110312 or 81100312. Not sure on the 2nd code number. This engine is in a Snapper garden tractor. It idles fine. When coming off idle it misses, sputters, and tries to die. I have it running, but not right. I need to play with the choke too much. I can only find one mixture screw. It is under the back side. It doesn't seem to do much when adjusted. This has a vacuum pulsation fuel pump. The pump appears to be part of the carburetor. I had it apart last year and cleaned all the inside and passages. Is there a way to check the pump to see if it is doing what it should? It must go directly into the bowl. Any links to this carb for diagrams or trouble shooting? I was told that the engine numbers told what the manufacture year was. What do the numbers tell you? Thanks to all in advance. I will give you feedback.
