wisconsin parts
88-1175
in need of a Wisconsin model vr4d cylinder jug from a 4cyl motor,has a 4.25 bore.doesnt need to be in the best of shape,a few cracked fins wont hurt for my application.all I need is the jug,someones gotta have one laying around,would take both jugs if available ???,my number is 724-nine two zero-8 four 7 zero
(quoted from post at 13:28:05 05/17/17) in need of a Wisconsin model vr4d cylinder jug from a 4cyl motor,has a 4.25 bore.doesnt need to be in the best of shape,a few cracked fins wont hurt for my application.all I need is the jug,someones gotta have one laying around,would take both jugs if available ???,my number is 724-nine two zero-8 four 7 zero
You might try here.
http://montesequipment.com/
Have had luck in the past with him.
Tom
Look up rock Creek consulting tim Stine
I know what it is and they are scarce back to you later
If I am correct that is a 56 hp flathead kind of a pre v465 size engine. They are scarce and also had issues crank I believe, besides valves. The company I gave you did have some if push comes to shove you may have to have a sleeve put in the jug.
