(quoted from post at 04:49:19 05/12/17) Father of one of my friends has one of those. Kind of interesting to
drive with the tiller steering. To check for spark, remove the plug,
hold onto the wire and have someone give it a yank.
(quoted from post at 05:30:56 05/12/17) 2x on holding to the spark plug wire while someone cranks it over. But a less defribrillatory method would be to take a new or any spark plug out of a known running engine. Then hook it to the plug wire contact the plug's metal base to the metal of the engine. Then have someone crank it over while you watch for a nice blue spark to jump the plug gap. The mag should have a clack, clack sound while cranking as the impulse catches and releases the armature to quickly swing it by the electrical spark creating segment of its rotation.
(quoted from post at 05:45:37 05/12/17) Remove the spark plug. hold the end of the wire and have someone turn the engine over slowly. Sure to check the spark. LOL
(quoted from post at 07:04:07 05/12/17) That is a base mount mag. Take out the bolts from the bottom . It should slide out without taking off the shroud. I think I have a mag like that on the shelf. If not I have a couple good flange mount that I can use for parts if need be. Mark the coupler before you take it off.
(quoted from post at 07:37:30 05/12/17) RTR,That looks like a FM-XIA or a FM-XIB Base mount Magnetpen your email and I will try to help you out with more info.
(quoted from post at 08:11:05 05/12/17) RTR,My email is open just shoot me a email.Is that a model AENLD Wisconson?
(quoted from post at 22:24:00 05/11/17) A shop manual on the magneto, the engine, and the tractor would be awesome to find.
(quoted from post at 19:38:16 05/12/17) I have no idea how to even get to facebook and no interest in finding out.
(quoted from post at 04:11:08 05/14/17) Forgot a something. Be sure to put all four belts back when you get
her done. Try to get 5hem all matched up. Also fix any slop.in
bushings and stuff. The other is one of the folks who come to the
Burrlington county fair have one. Think the story was no one ever
checked the transmission. The poor think was ripped to crap inside.
Had to find a good used one to the tune of a couple hundred. CHECK
yours!
(quoted from post at 06:29:46 05/14/17)(quoted from post at 04:11:08 05/14/17) Forgot a something. Be sure to put all four belts back when you get
yours!
Thank you! I will be checking it because it doesn't SHIFT easy. No smototh detents. It's very stiff
(quoted from post at 02:35:04 05/15/17)
You have a good dog. Looks like he enjoys watching you take on different projects and keeps you company. Sorry I can't help with your problem but it helps to have a good dog.
(quoted from post at 13:02:43 05/14/17)
Does anyone out there know a good guy to rebuild this FB Magneto? I took it off last night and cleaned points really well and cleaned all contacts. Put it back on and no spark. Impulse seems tone working fine.
(quoted from post at 16:38:57 05/15/17)(quoted from post at 13:02:43 05/14/17)
I'd change out the condensor before sending it out to anyone. Without a known good condensor you won't get any spark. Look for bare wires or grounded wires too. Beyond that, any mag shop can rebuild them, real simple stuff as long as you can get the parts.
(quoted from post at 15:38:16 05/12/17) I have no idea how to even get to facebook and no interest in finding out.
