ohiojim
anyone know who made these remotes, they have an internal leak, also any help with finding a rebuild kit or a new set of remotes.......thanks JIM
I called them, they don't manufacture anything just resale..I've called some local hydraulic repair places and they're at a lose also. seems my luck is holding....LOL
If you want different remotes, go to a combine salvage yard. Older IH< JD<Gleaner combines used Cessna valves. Can put as many "slices" together as needed for your circuits...single, double acting. Simple O rings seal between slices. Just get longer connecting bolts.
Entire msg did not post.....combines used Cessna valves. Put as many "slices" together as needed. O rings seal between slices. Get long enough bolts to hold them together.
